99Yam40 and Robert
First..... Thanks for responding to my post........... 99Yam40 you are correct it's popping through intake, which only happens on the top cylinder on both sides. I also have 135psi compression on those two cylinder in all others I have 150. Robert, I bought the boat knowing that the fuel system needed to be cleaned and it had been sitting for a year. I cleaned or replaced all injectors/filters and fuel pumps in the fuel system. I have lower compression in the same two cylinder that it popping through and no problems with the others, I'm not sure what would cause this...... Any and all help is much appreciated
Eric
