Yamaha 2004 2stroke 150 TXRC tilt lock lever "sloppy" on the starboard side - Replacement
My 12 year old 150 2 stroke is having some issues on the tilt lock lever. Starboard side lever is very loose. Looks like there is some sort of connection collar with pins on the starboard side of the lever and I see what looks like some white color plastic grommets on the shaft. Service manual shows several plastic parts and some roll pins holding everything together. My question is, is this something I can change out at the house of should I see a professional ? It looks fairly straight forward by looking at the service manual however not sure how to get the roll pins out ? It's pretty confined work area as well. Do the pins just push out with perhaps some sort of punch ? Any tips or tricks appreciated. Would appreciate any experts weighing in on type job..
Thank You !
Thank You !
