Hi,
I recently bought a Suzuki DT100 and I felt it was quite weak, so I tried to measure the compression on it. The result for all four cylinders were 8, 8, 7 and 5 bar. So I suppose that explains the weak engine.
What do you think, is it worth trying to repair it? I suppose the error causes can be piston rings or cylinders most likely? I can not feel any air leakage around the cylinder head sealings..
Thanks in advance for advice
/Viktor
/Viktor
