I have an 87 DT150SS (Super Six). Until recently, it ran great. I'm now experiencing a high idle condition.
At startup, it idles around 4000 RPM and never drops down. It has an idle speed selector switch that has no impact on the RPMs when I move it to either of the 5 positions. I just replaced the throttle valve sensor with no improvement. I also replaced all fuel lines to ensure I didn't have a cracked fuel hose introducing extra air into the system. I placed an ohm meter across all five idle switch positions and got the following readings from low to high (open circuit, 20 ohms, 6 ohms, 2 ohms, 0 ohms).
The motor idles too high to even attempt putting it into forward or reverse gear. I don't want to blow up the lower end.
QUESTIONS:
1. Do the ohm readings on the idle switch seem consistent with a properly working idle switch?
2. Can anyone provide any suggestions that could cure my high idle issue and get me back on the water?
Any help an/or discussion would be extremely appreciated. I'm 60 miles from the nearest dealer and want to fix this on my own.
Thanks - Craig
QUESTIONS:
Thanks - Craig
