I bought a 94 Harris sunliner 24ft pontoon from some people that had it sitting for 4 years. Bought it, cleaned it and got the Yamaha 55hp 2 stroke running again. Ran all last year and it was super slow rpms only made it to 3500 but controller seems to have a lot of throttle past that. Figured it was my prop it had some dings. When I pulled it I found no numbers left just corrosion all I know is it's 12 inch. Took it Yamaha dealer he gave me a prop after looking at mine and telling him my problem. I left with a 11 1/4 inch x 10 pitch. Tried it and got up to 3900 rpms at top side again a lot of room left on top side of controller. But this time my 24 ft dock was actually moving noticeably faster, front end rose right up and I usually have to trim it to do so and it was all the way down. Also realized I cruise a lower rpm threw wake zone too. But when I look at specs I find rpm rang to be 4500-5500 on motor. Will this prop work or are low rpms gonna make some thing happen to motor? If I do run prop can I run 3900 rpm down the lake or should I back off a little?
