Permission
- Jun 19, 2017
- 1
Twin 250hp OX66 year 2000. Port motor will cut out at 3600 RPM. Cuts out completely as if the key was turned off. Starts immediately afterwards with key switch. Motor powers up perfectly and will run below 3600 no problem. a minute or two above 3600 and - off.
Have done ALL fuel related checks. someone suggested possible voltage drop via ignition switch ? or battery switch ??
Any advice is gladly received.
Thanks in advance.
Thanks in advance.
