I hit a rock going about 5mph. The boat and motor just dragged over rock. The skeg is scraped up and it lifted boat slightly (161 Angler Smokercraft). I tried to lift motor with tilt to see damage and motor only goes up to I think the limit while running.
I got home bleed some air out of unit. Put motor up on safety tabs, disconnected lower mounting bolt/shaft, ran unit up and but it does not go into 'high speed gear'. Rechecked level after running up and down about 6 x. Remounted lower end of trim unit.
It will not lift motor above that point before it's breaking out of water...that high speed up point.
Any ideas or help appreciated. Motor only has 225 hrs on it. It's a 50TLR 6H5K L 1010857 K
P.S. I have had the skeg replaced/rebuilt 2x hitting rocks so the motor gas had some shock. This is first trim unit issue.
