SouthCarolina1
- Jun 17, 2013
- 165
I have a 1989 115hp 2-stroke Yamaha that I am rebuilding. One cylinder had 50 psi and the other three were at 128-130 psi. The block and camshaft are at a shop being cleaned and inspected. I am prepping the other parts for re-assembly and I ran into a snag. One of the piston heads that had good compression, has two batches of light scoring but none on the sleeve. Would you just clean it up and reuse the piston OR should I get another one (would buy another used one off of ebay). Assuming cylinder doesnt need to be bored. See pictures
