Jim Hawkins
- Mar 11, 2013
- 499
The motor is a Yamaha, 90HP year 2003 (I think) When I first got it several months ago it would do about 30mph at close to 5000 RPM as setup. Recently I have lost top end power. It still runs very smooth at idle and under power, it just does not get above 3500 RPM's and about 23 mph anymore.
I first checked the linkage to the carbs and verified the throttle was moving them the full range with no apparent problems.
I checked compression - 110 PSI in all three cylinders, the same as when I bought the boat a few months back.
Next I considered it may be running on 2 cylinders but placing a hand over the throat of each carb in turn while idling affected all 3 the same.
From here my best guess is to pull and clean the carbs but not wanting to put in that work unless needed and also considering Murphy's law and the "If it ain't broke, don't fix it" idiom I want to be pretty sure thats the best solution.
Any thoughts on pinpointing my issue?
Thanks.
Thanks.
