I have a Yamaha 6hp 2cycle (older motor) I am leaving set for the summer in Florida. Is it better to run all the gas out of the motor before storing or leaving some in the lines and motor? I have been using Sea Foam all winter in it so the fuel has some stabilizer in it. Just curious if the gaskets or seals will dry out if I completely run it dry. Thanks for any help you can give me
