Test Yamaha tilt/trim pump
Scott_K
So my tilt quit working, I narrowed it down to the motor. Replaced it and still nothing. I have pulled it on and off three times, I know I have it on there correctly.
Motor spins but no action, any ideas?
Yamaha F115 MY 2000
99yam40
what was the problem to start out with?
maybe you left the coupling off
boobie
Good question. Is the coupling there ?? Is the manual relief valve closed ??
Scott_K
Yes manual relief valve is closed. Pump motor spins but not building pressure. No leaks or anything I have no clue how to test the actual pump.
