timlovesfishn
- Feb 6, 2017
- 6
I ran my boat with a Suzuki df40tl efi 4 stroke the other day with no problems. Started and stopped multiple times without any issues. I brought it home and went to flush the motor and it wouldn't fire up. Cranks without any problem but just won't turn over. I don't believe it is the fuel since it has been used regularly lately and I have been keeping it filled up with high test. I checked all the basics first, the boats in neutral, kill switch is attached.. I've unscrewed the bolt at the top of the fuel rail and nothing sprayed out so I assumed it was the high pressure fuel pump and replaced it. I put everything back together and was expecting it to fire up but again nothing but the cranking of the starter. I doubt it's an issue with spark because I've sprayed the throttle body with throttle body and injector cleaner and it turned over briefly and than trying again after the cleaner burns up and the engine dies gives me the same result. I'm beginning to think that it might be a faulty switch. Probably the safety kill switch which I may attempt to by pass this evening to see if it will turn over. Any help or advice is appreciated. Thanks in advance.
