I am fixing up a 1987 suzuki dt115,motor satup for 10 years.previous owner says it lost power and his boat wouldnt plane out.....so it sat there till i recieved it.
I rebuilt the carbs,changed waterpump and driveshaft bearing housing.
Ignition switch was faulty....new ignition switch.
First fire up she ran great on land,after 30 mins of running max outside cylinder temp reached 128 f.
Put the boat in the water and she wont plane out,ran great below 1/3 throttle.past 1/3 throttle she starts missing and bogging.
Ive ruled out fuel being the issue,if i apply any amount of choke she will lose more rpms and die from flooding.
Electronic parts are pricey for this ol zuki.
So before i start throwing parts at her.....does anyone have any information on testing the sensors?
I tried unplugging temp,tps,and oil sensor.....no change in performance.
Compression is around 140 psi on all 4 cylinders.
All plugs fire.
Thanx for any insight......advise.
Im leaning towards throttle position sensor,ir cdi unit.tps tells cdi how much advance timming to send engine.
All plugs fire.
