I just bought a boat with a early 90's DT 85. Prior owner was clear with me about the issue and price was right. He told me he had taken it to a guy and had the carbs gone through which I tend to believe.
It runs just fine at idle/neutral but put it in gear and put some load on it and about 20seconds later it dies suddenly. No sputtering like it is starving for fuel just stops like key is turned off.
Before I go chasing through the fuel system is there an electrical cause I should be checking on?
My plan is to get rid of the 2-stroke in a year or so when I find the right deal on a 4-stroke so I don't want to start firing the parts cannon at it. If I have a fatal (read expensive) fix on this engine I will accelerate the search for the 4-stroke.
Thanks in Advance.
Thanks in Advance.
