I currently have an 89 Pro V 150 that ate a piston. I was told that I cannot resleeve these blocks so I have opted to replace the block with a good used one. My question is, is there a difference in th Pro V blocks? I will be using crank, heads, carb setup, flywheel etc., from my old block.
I have found a non Pro V block of the same year. Will this work?
