Jim Hawkins
- Mar 11, 2013
- 499
I'm looking at buying a boat with a 2004 90hp Yamaha TLRC. When I checked out the boat my Compression tester showed 90# top cylinder, 90# middle and 60# on the bottom. I assumed the motor had issues and left.
Next I looked at another boat, again a 90HP Yamaha and again off on compression.
When I got home I checked my compression tester on my boat motor and again, low compression. I fiddled with the tester and hooked it up to my air compressor. The tester showed 120# close to the same as the gauge on my compressor. I then checked my motor again and got 110# on both cylinders as it should be. So now I am doubting both my ability to do a compression check correctly as well as the heath of my tester.
Question 1 - does it matter if the engine is cold or hot when you test compression?
Question 2 - do you really keep cranking until the gauge stops climbing? (even if that means cranking for 10 seconds or more?)
Question 3 - is it wrong that 2 to 3 seconds of cranking is enough and also that you should test each cylinder the same?
Question 4 - does a compression tester need any maintenance, like a drop of oil from time to time like an air nailer tool?
Thanks for any responses.
