Anyone know why my trim rams are not going in or out? The tilt rod goes in and out like butter when i power it but the rams will not budge at the end of the up or down cycles. However, when i open the manual release valve the rams can be pushed in easily. there are no leaks coming from the unit anywhere. I have the unit on a workbench and have bled it entirely. I have taken the rams out (all three...trim and tilt) and all the o-rings/seals look perfect as well as the cylinder walls. I'm using Dexron tranny fluid, by the way.
Does anyone know what the culprit might possibly be? any ideas?
