Hello all from Bahrain. I purchased a boat not long ago with 97ish twin 200 carbed 2 stroke Yamaha's. I originally had an issue with one engine, but now it is both.
Upon taking off, one or both engines will not go to [COLOR=#67B045 !important]full throttle(about 2500rpm), even though the [COLOR=#67B045 !important]lever[/COLOR] is full forward. I can come to find that I can stop the boat, kill that engine (or both if needed), go full reverse then back to neutral. After this procedure, the engines will hit 5400+ rpms and will throttle up and down just fine. It seems to be when hitting nuetral or part throttle in reverse that something is getting out of wack.
I am at a [COLOR=#67B045 !important]loss[/COLOR] as to whether it is in the cables, the actual throttles, or something on the engine side.
Any ideas?[/COLOR]
Any ideas?[/COLOR]
