CarabbeanSafari
- Oct 25, 2011
- 25
Hi Guy's, Im going to try in here, I am having heaps of trouble getting help, even from mechanics in the area. Engine is an E50PL4SI 50 HP 4 stroke, everything on it including wiring loom is Suzuki just has an evinrude cover. Mechanic plugged it into his software getting 2 codes CTP Switch and Map Sensor, there were no provisions to clear these 'current codes', there were codes from the past including manifold temp sensor and overheat. Can anyone please tell me if the ONLY option is to replace these 2 items?, also if I do replace and it works will the codes clear themselves?. Engine/boat was dry stored for 6 months, no troubles before hand, upon first running of the season engine appears to be stuck in slow mode and comes up with these two codes, at 3000rpm the engine has a violent miss/limiter symptom.
Is there also any combination of ignition/lanyard/battery switching that can remove these codes?, Thanks for any help
