2006 225hp Johnson(Suzuki) four stroke.
I have a 2006 225hp Johnson that everything I have researched says it is 95% Suzuki. Engine has performed flawlessly for a couple years. This summer, it started showing a check engine code at idle speeds. I was having a problem with neutral safety switch and tachometer. Replaced neutral safety switches and tachometer and now engine will not run? I'm not getting a ground from the ECM to the fuel pump? Any help?
