I have had some troubles with batteries in my F150 recently and even a blown fuse or two.
Yesterday I was running with only my F150 connected to the battery (no accessories) and noticed after 45 minutes or so the analog tachometer starting varying by more than 3000 rpm even though the engine did not change rpm.
Many years ago this happened to my Evinrude 2 stroke and it was the rectifier. I've also seen some odd voltages (like 16V on both my depth finder and analog in-dash volt meter).
Has anyone encountered a failed rectifier/regulator on a Yamaha 4-stroke? Would you expect the rpm to vary widely if the rectifier/regulator was out?
