jmitchunc23
- Aug 24, 2016
- 1
I have a 1987 Suzuki dt140. recently the trim stopped going up and down. when you press the up and down switch you hear the motor running but no movement. I checked the fluid and it was very low. I backed off the manual release to lower the motor but ended removing the screw completely and noticed one of the orings was shredded. I replaced the oring and filled with atf fluid. still no movement just hear the motor running. any help would be great.
