jedimaster
- Jun 8, 2006
- 336
Hey, so I am hooking up the gauges and I can't see a fitting for the water presure. There is a temp Guage on high side block that I thought was supposed to be where the temp goes. Is it OK to just remove the bolt on the other side and put a fitting in there for the water pressure? Can I tee off of one of the other lines that are external or should I move the temp sensor to the low side and put the water presure fitting on there?
