alexedit
- Jun 16, 2007
- 32
Hey guys -
ok, so the problem started about a month ago when I was going half throttle a motor just shut off and it wouldn't start.
That turned out to be the connector on the vapor separator tank (VST). The connector was not sending power to the pump.
I bought a good used vapor separator on ebay and a new fuel pump. That worked...BUT
Now the motor behaves like it's starving for gas. It has only about 30% of the power.
Here's the crazy part, when I crimp the return line that goes from the fuel pressure regulator back to the vst, the motor runs perfectly fine. What in the world is going on? :/
I thought it was the fuel pressure regulator located on the bottom of the fuel rail so I changed it....no luck.
Any ideas?
Thanks in advanced
Any ideas?
Thanks in advanced
