After running all day, when I was coming back to the dock through a no wake zone I noticed it was running rough at around 1000 RPMs. Didn't think much about it so I continued on. I stopped to let everyone swim and on startup, there was excessive smoke (a lot). I moved on and noticed I was out of gas in the tank I was running on so I switched gas tanks. I figured the problem was that the smoke was because it was just burning oil instead of gas from the oil injection system.
I figured that my plugs were probably pretty well soaked but after running at higher speed, hopefully they would clean up. I ran it all the next day and again, it ran rough around 1000 RPMs, quite a bit of smoke at startup and low idle. So now, I'm home and trying to figure it out. Here is everything I know:
New plugs are now completely fouled with oil
Good compression (130 on all four cylinders)
Recently rebuilt carbs
New oil pump (remote tank)
New oil lines and filter
Oil linkage hooked up correctly
I'll of course replace the plugs again but if they're going to keep getting fouled, I need to figure out why.
Thank you for your help!
