digital tach stopped working. warning indicators arn't working either. warning buzzer is working. checked power on yellow wire and gnd. thats good. is there anything else i need to check before changing guage?
Although the problem you have is "electrical" in nature, it is an "engine specific"electrical issue so you would get better response if you post the question in the Yamaha Engine part of the form. This Electrical forum is for boat related electrical system problems.
service manual will show how much peak voltage you should read at different RPMs from the lighting coil with the proper test equipment.
Tach reads pulses
