I noticed that my engine mounted oil tank was about 1/2 full after fishing one day when it's normally filled to the upper line on the tank. I thought that was weird so I tried the emergency switch to see about just pumping more oil into the tank but nothing happens. I checked the manual and it said to take ohm readings of the float to see if that's working and if it is, check to make sure you don't have corroded connections and if that's not the case, I should replace the CDI. What about checking the pump on the remote oil tank to see if that's working. Anyone know how to do that before I buy a CDI?
Thanks for your help.
