Hi all. Need some help. I have the bearing carrier and shift shaft removed from the lower unit, however the prop shaft won't slide out. It will slide back about an inch, and then stop with the clutch. It acts like the shifting mechanism on the other side of the reverse gear is hanging up on something. With the shift shaft in, the clutch slides back and forth properly. Is there anything else that I need to remove?
