I posted this issue last week and received some good mechanical advise.The problem however still exists. The cranking is weak to start and then slows down and stops after 8 or so seconds. The starter and starter soliniod checked out,the battery is new and the cables are in good working order.I spoke briefly to a very busy mechanic and he stated that their is a bushing located on the drive shaft that maybe corroded and could be responsible for the laden starting of the motor.He suggested taking off the lower unit and then hand cranking the flywheel to see if it is in fact easier to turn.My question is, does that sound feasible and if so, where is this bushing located, and is it a challenge to get to and replace? Thank you Andy
