I have a piston issue...I'm rebuilding a 70ETLH Yamaha ('87 3 cyl 2-stroke); that was built factory w/ 3-ring pistons, so I ordered 2x replacements (STD size) but rec'd 2-ring in lieu of the 3-ring piston I thought I ordered per the PN I was given from a supplier. I am being told these will work for us & shouldn't be a concern; also told that there MAY be a certain block design that requires a 3-ring piston over a 2-ring.
Does Yamaha have varying block designs for this model? Will these 2-ring pistons work well as a replacement?
Any help is greatly appreciated. Tks.
