When replacing the water pump, the threaded connector (for the shift linkage) was frozen and I snapped the vertical shift linkage that goes up to the powerhead section. I don't see a way to remove the rod due to lack of clearance from the powerhead. Is there a good (easy) way to remove and replace this shift linkage rod???
...Thanks, Bill
...Thanks, Bill
