Blacktalon82
- Apr 12, 2016
- 10
1993 Yamaha 200 Hp
2 Stroke
200TXRR
6G6 UL 763768
900-950+ hours
Yesterday spent several hours on the water with no issues whatsoever. Came back in for a short storm to pass, then headed later that night to the marina to put it on the trailer and the motor was smoking a lot even after warm up and while underway. This old yami isn't a smoker usually at all, and has been very reliable so it was very odd to see all the smoke. It didn't smell off, tell tale was still pissing strong, and it did not cause the motor to run roughly or hesitate to start. The smoke was lighter in color toward white-ish.
Today however, after a long drive to fish the Chesapeake bay the boat refused to start when we put in. Tried everything I could think of, and eventually flooded the motor from repeated tries Took off the cover and the air intake to let it air out...then tried again. Would not turn over, just sit and try and try and try. A couple times it coughed a little smoke, but nothing more than that. I've gone over the engine (as close as I could while on the ramp) and only found a small crack in the fuel filter housing slightly leaking gas. Nothing else looked out of place that was obviously off.
I'm at a loss as this motor has been nothing but reliable. The heavy smoke had me concerned, the non start has me even more worried, so I was hoping for some help. What would be the order of things to check from these symptoms?
Thanks in advance.
2 Stroke
200TXRR
6G6 UL 763768
900-950+ hours
Thanks in advance.
