Hi,
I have 02 F225 about 1k hrs
Idles great runs great but having strange problem it will start to miss and run rough just off idle 800-900 rpm then clear up above that .
I connected Laptop and ran diagnostics I get code 37 Air intake passage ? The TPS is adjusted to spec and everything else seems ok . I took off IAC looks clean ?
It seems to happen after 10 -15 minutes after warm up ? stumped on this one ?
