I have a 15 hp 2 stroke yamaha, less than 1 year old. I have a racor in line fuel water separator with recently replaced filter.
Engine has been running fine until yesterday. It would stall right after starting but after 3 tries, it ran fine. Now today it will not keep running. It will start with the choke on and with the throttle up, it will run for about 5 seconds before stalling. If I push in the choke it will stall sooner. If I throttle down towards idle it will stall right away.
New racor fuel water separator.
Changed plugs, old ones were pretty fouled.
Sprayed carb cleaner into air intake.
Pulled needle valve and sprayed carb cleaner there.
Oil mix should be close to 100:1.
Seems a very specific problem so the issue should be pretty specific as well.
Hoping to not need a rebuild of the carb.
Thank you
Thank you
