ericgormley713
- May 3, 2016
- 30
I have a DT75 1989. I have replaced the following:
Fuel pump, spark plugs, boots, throttle sensor, fuel filter, starter, and we have cleaned and rebuilt the carbs. Engine idles great, accelerates fine, but once it gets up to full speed it begins to feel like it's not firing right. When i bring the throttle down, it runs normal. Any help would do. The mechanic has tested the voltage of the throttle sensor, along with synced the carbs. Help if you can, Thanks!
