Hey guys. On our run out to catch some Dolphin with everyone else and their brother on Saturday, I had a set of strange occurrences with my motor and throttle.
The short story is that running along at about 5,500 RPM (30 knots or so), the motor would straight up die, accompanied with a disconnecting gear sound from the throttle quadrant. Seemed like it was popping out of gear with the motor still running, and when I pulled the throttle back to disconnect the gearing, the motor would be dead. It was the same noise that happens when you don't quite put the motor in gear and it "grinds" for a few clicks. You know what I mean? The ratcheting sound happened exactly when the motor would die. Once or twice I was able to grab the throttle and pull it back out of gear, and the motor did not quit. It did this once on the way out, about 45 miles into the run out. The motor started right back up, and ran through the whole time trolling, and all the way back past Ft. Sumter. Once in the harbor, it did this repeatedly. It would die with a ratcheting sound. After about 4 or 5 times doing this (trying to run the motor at a low RPM, mid range RPM and so forth trying to see if that would make a difference), it finally would not start back up. My son noticed that the primer bulb was completely flat at this point. I worked the bulb, and eventually got it to inflate and fill up with gas. I primed the motor back up, and it started right up and ran the rest of the way to the ramp (about 2 or 3 miles or so) without dying or giving me that ratcheting sound.
Over the past two seasons, I've had a lot of issues with the motor quitting on us that we have worked on and fixed, or so I thought. I've never had the motor die with an accompanied noise before like this. Which is why I'm so concerned about the combination.
As far as the bulb is concerned, yes, we opened the gas cap right away when we saw the bulb was flat, and let it sit for a minute or two, but the bulb stayed vacuumed shut.
Has anyone every heard of, experienced, or seen anything like this? I don't know a lot about outboards, and what I do know comes from all the work I've done on it myself using a SELOC manual and some great advice and help from those who do know. But it seems to me that if the motor is slipping out of gear, there might be a fail safe for the motor to quit if this happens uncommanded, making me think that I have a gear problem, not a motor problem, because the motor ran great all day, and started back up every time, the first time, except that last time.
Thanks for reading this, and offering whatever help you can.
