BassBoats75
- Dec 27, 2013
- 20
Hey everyone so I have a question recently my Suzuki has been running like **** and I took it in last year to a dealer that doesn't specify in suzuki well all never go back to those guys well anyways long story short so Yesterday I took it out for a speed test after finally figuring out why it was running so ruff Spark Plugs lol I got 3 new spark plugs then put all new 89octane Gas in her and took her to the lake with the motor running finally at a greater speed without coughing this time well I was running around at 31.6 mph then I started to hear a knocking sound I don't understand what is causing it my water pump is pumping water fine but anyways when I was at WOT at 31.6 SOG it made that sound and then if I left it it would eventually start to slow down the grinding would get loud then dieeeee.... it also has a carb issue I believe I'm gonna order new gasket and stuff but at a slow idle if I engage it just a hair or 2 past while already in gear it will run riff then die the only time it doesn't die is if its engaged at 4.5 to 5mph thanks guys I'm not to mechanic savvy but I'd like to learn something be nice but that grinding sound can't be good .
