Hi,
I have a 5hp 661 BS air cooled Yamaha which seemed fine when i bought it a few months back. Now I find that the engine will not run at high revs for any length of time. Also cuts out at idle after ten minutes or so.
Stripped carburetor, cleaned and replaced. Fuel pump had some crud in it which I have removed but not sure how to test it is drawing properly. Seems fine tbh.
Seems to be a fuel problem. I have a long line on it to the fuel tank - is that likely to be a problem?
When I kept it on high revs last time, I pumped the fuel through with the primer bulb and it did not like that at all and stalled with a backfire, smoke coming back out through the air intake (air cooled).
Great starter and runs fine (until it just stops) or unless it is kept at very high revs for a few minutes. Seems to be starved of fuel but not sure why?
Any thoughts? Not much to the engine really, which is why I am at a bit of a loss now.
Thanks.
Thanks.
