Last week when I was out one of my HPDI 250s suddenly lost power and dropped from 3800 to 2600 rpm. I've had this happen before so I went right to the Mystery Filters and changed those out. Test run and still only get to 2600 rpm. Diagnostic software shows 6psi on the low pumps and 950-1050psi on the high pressure pump. The number for the high pressure changes quickly between the range. Is that normal? I checked the fuel pressure at the the VST today. It goes to 70 psi for the first five seconds and then drops to 40 with the key on only. Running at idle it shows a constant 62 psi. If I put 15mm of vacuum to the fuel pressure regulator it will drop to 55 psi. I see no change when I pull the vacuum line off the fpr at idle. I've ordered the Mid pressure filter and am waiting for that now. Any other suggestions as to why the electric fuel pump is showing so high?
