Hi I need to change the trim motor on my outboard. I have undone the trim assembly but how do you actually get it off as it seems wider than the bracket itself
You should be able to take the trim motor off with out taking the whole trim unit off. I am pretty sure to get the trim unit off the motor has to be removed from the boat.
