Twin 1996 Yamaha 150hp Salt Water series engines. When I turn the starboard ignition key to "ON" position, the starboard engine T/T turns on and raises the engine. This does not occur with the port engine. Standard Twin Binnacle Controls with separate T/T switches and single switch on port control lever which raises/lowers both engines simultaneously. Any thoughts on where the problem is or how to isolate the problem?
