03svtsnakevert
- Jan 3, 2016
- 2
I just recently started having this issue. I took the boat out on Saturday and upon start up I noted that it smoked kinda heavy...however, it seemed to settle down... As I was idling out of the canal and had been idling for about 10 minutes, the engine stumbles and shuts off. Upon trying to restart it would turn over, try to fire and immediately die...if I let it set for a little while it would start back up....I was able to run it up and down the lake at speed with no problems, but the moment I started idling it would die and go through the hard starting or not at all....I would have to let it set like it was flooded or something...I also heard an audible alarm when I would try and restart the boat...no lights, just the audible horn...today I checked the LP by unbolting them from the block and pumping the bulb. I noted that I could pump the bulb and see fuel enter the filter and fill up and the bulb would get firm...after awhile I would have to pump it up again...when I got it started I pumped the bulb to see if the RPM would change and it did not. When I got it started today I let it idle for awhile and about the same time as the day prior it died and would not start...then it would just turn over and not try to start...I have been trying to read up on this but it seems that everyone points in 500 different directions...I have checked the oil sensor in the tank and it checked out...I checked the vst for flooding according to the manual, but I am not sure I pulled the vent tube when I checked it..
Looking for some insight here and I will answer any questions you gurus have to give you as much info as I can to help me diagnose and solve this.
Thanks!
Thanks!
