Hi Everyone,
2000 Yahama SX 250hp OX66, 3 blade prop 15-1/4"X15"-M.
Boat: 1989 Mako 231 with A&J bracket.
Motor runs fine for a while (15-25mins) at all speeds and RPMs, soon as it gets warmer and hits the 4000rpm or over, shuts down, like if I turn the key off!!
Motor cranks right away if I cycle off-on the key!
This is what I checked and replaced so far:
O2 sensor brand new and clean.
VST filter clean, preasure regulator screen clean.
New VST gasket.
Inline fuel check valve gutted (I was good, but removed just in case).
Injectors clean (fuel injector man).
Fuel preasure on rail @ 40psi.
3 new low preasure pumps and gaskets.
TPS voltage check, 0.50v fully closed, 3.8v at WOT.
Compression 110 all 6.
New spark plugs.
Spark gap good.
Gas and tank are brand new, all filters are new, and new yamaha primer bulb as well.
Motors idles fine, minimun smoke.
At this point im clueless!! Just order a winky blinky harness from SIM to check on the other sensor...
Any suggestions??
Thanks,
Eladio
New VST gasket.
New spark plugs.
Spark gap good.
Any suggestions??
Thanks,
Eladio
