Codybentley25
- Nov 29, 2015
- 10
Needing some help diagnosing a problem with my boat motor it is a Suzuki dt40 oil injected it will not get spark what so ever. I'm thinking it my be the CDi /ignition which is built together I'm no expert but am looking for others opinions on how I may be able to do more test to figure out if it could be something else. I have checked the pulser coil which read good also have checked charging coil and the emergency kill switch and then disconnected it from the Cdi and still haven't had any luck. Help would be appreciated. Thanks.
