Melbournite
- Oct 4, 2015
- 20
Have a 1997 70 HP Yamaha 2 stroke. Having overheating problems. Have replaced impeller, checked thermostat is opening, pulled bottom leg off and had hose stuffed up water intake pipe and water seems to be getting up into cylinder head water jacket. . Have removed cylinder head and exhaust covers and cleaned out all of the salt build up. Now at a loss as what to do next. There seems to be a lot of water coming out of the front of the lower leg unit overflow so am thinking the water intake pipe is not connecting with the water pump housing outlet so water is not getting up into the water jackets. Any suggestions/thoughts?
