natemoore
Master Chief Petty Officer
- Jun 13, 2009
- 844
My new (used) Triumph 190 Bay has a Faria tachometer that is inoperative, a speedometer that is disconnected, and a fuel gauge that works. The prior owner wasn't aware of any over-temp or low oil pressure alarms on the motor or indicators in the instruments. I would like to monitor more parameters if it is possible, e.g., oil pressure, temperature, voltage, RPM, and whatever possible.
It there a simple way to replace the original gauges with better ones? Are there wiring harness connectors just waiting for the right instrument to be plugged in?
Thanks in advance,
Nate
Thanks in advance,
Nate
