Yamaha 15 hp two stroke starts in gear
dduhaime
Recently, my Yamaha 15 hp two stroke has changed so that I can start in neutral, forward or reverse. Previously, I could not pull the start cord while the shift lever was in forward or reverse. I would like to fix this but do not know how. Any suggestions? Thanks
99yam40
take off the cowling and inspect the device that locks out the start when in gear. something is stuck or broke, as it should only let you pull the rope while in neutral
