salprofish
- Aug 27, 2015
- 1
I've been having some trim issues lately, 1989 prov 150 2 stroke ive owned it for 3 years with almost zero issues until a few weeks ago. When the engine is tilted up out of the water trim switch on the shifter/throttle works fine up or down until its lowered to the slow/ halfway position then it will not trim up but will trim down. The switch on the engine works fine up and down. I was told by a " Yamaha tech" that its a bad switch, put a new switch on still have the same problems. I called and talked to another tech. at a different shop and he said its prolly the trim relay, sounds good to me except all the wiring for the switches tie together before going into the relay, so that's not it. Really frustrating getting the runaround if anyone can point me in the right direction I would really appreciate it, Steve.
