Will only tilt up when in neutral so can't trim it up when running forward,
R rkomows Recruit Joined Aug 25, 2015 Messages 1 Aug 25, 2015 #1 Will only tilt up when in neutral so can't trim it up when running forward,
9 99yam40 Fleet Admiral Joined Sep 7, 2008 Messages 8,880 Aug 25, 2015 #2 if you check you modle # it will probably tell you it was not made to trim only tilt
