wahoochaser
- Aug 22, 2015
- 3
Hello I have search and read all the post about the yamaha precision oil system. Right now it is not to precise. I have 2001 yamaha ox66 250 and the port engin work with no issues. The starboard motor will only transfer oil from the remote tank to the main tank using the bypass switch. I have removed both tanks and cleaned them. Remote tank had filter replaced along with remote tank sensor. Made sure that the oil lines were not clogged by blowing air through them. Replaced main tank sensor switch assembly. Pump was tested with battery and workes fine. I am getting power to the pump on the brown wire. Have checked all the wires i know to check and found no breaks tested continuity. The tach has the middle bar blinking indicating yellow that the remote tank is low which it is not. I have switched tachs and it does not change anything. I even left it unplugged and it still flashed yallow when the key was turned on. I am out of ideas and am at thinking of just running it and having to stop often to fill the main tank which will be a pain. Any idea would be awesome.
